Discussion topic: Poor WiFi strength
Message posted on 26 Nov 2025 11:11 AM
Poor WiFi strength
Message posted on 26 Nov 2025 11:18 AM
Re: Poor WiFi strength
@Zoe163 & @LunaCasbolt Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes of. any size. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
