Discussion topic: Poor WiFi signal
This message was authored by: Gjeff
Poor WiFi signal
The WiFi signal is poor and doesn't reach all rooms in house,I'm a new customer and should have received a booster with the hub but no booster was delivered
Re: Poor WiFi signal
Did you request a booster as these are not sent by default but will be sent if you have the wifi max add on at £6 per month on your account.
Avatar for Gjeff
Yes I did add on the booster for £6 per month which took my monthly cost to £35 per month
You need to get in touch with Sky about getting a booster sent to you:
The first one can be self installed while a second and third will require an engineer visit.
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
