Discussion topic: Poor WiFi signal
Message posted on 23 Jul 2026 11:39 AM
Poor WiFi signal
Recently moved from Virgin to Sky, we have 500MB and the signal keeps dropping out upstairs (in a modest new build
property). Needs addressing as costing us a lot more in mobile data.
Message posted on 23 Jul 2026 12:21 PM
Re: Poor WiFi signal
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
