Discussion topic: Poor WiFi signal
This message was authored by: Mcfly88
Poor WiFi signal
Pay for 300 meg. It's currently pulling 18 mb. Nkt good enough.
Re: Poor WiFi signal
Hi @Mcfly88
The speed you pay for is the speed down the line to your router. If your using WiFi this speed may be significantly lower due to WiFi factors that are out of Sky's control. To get the maximum speed you need to use an ethernet cable.
I am NOT a Sky Employee
