Discussion topic: Poor WiFi signal
This message was authored by: EricF51
Poor WiFi signal
I recently received a new router. the WiFi signal no longer reaches areas of my home that the old router did. I have run diagnostics and everything comes back as ok but the signal strength isn't as good as with my previous router. Can you please advise of how I should progress?
Re: Poor WiFi signal
Hi @EricF51
Which Sky hub did you have before & which one do you have now? You can find the names & pictures of them here https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
I am NOT a Sky Employee
