This discussion topic has been answered Discussion topic: Poor WiFi signal
Message posted on 29 Jun 2025 09:52 AM
Hi there, I recently switched to Sky broadband to get a stronger internet signal. Unfortunately this only seems to be the case in my living room where the router is located. Devices outside this room are having problems connecting and using the internet. We are in a new build house, so the walls are not solid and the house is not huge.
could you provide some advice please.
thanks
kieran
Message posted on 29 Jun 2025 10:15 AM
If you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Message posted on 29 Jun 2025 11:15 AM
Re: Poor WiFi signal
Thank you! I don't have it, but will upgrade today.
Message posted on 29 Jun 2025 11:31 AM
@Kieran54 Even though you have a new build and the walls are thin, YOU have no idea what is there, if you have foil lined plaster board then wireless wi-fi JUST does not like it in the slightest, and is very evident when you leave that room the hub is in!
Message posted on 29 Jul 2025 05:56 PM
Only devices near my router work coverage is poor
