Discussion topic: Poor WiFi signal
This message was authored by: Bags264
Poor WiFi signal
I've recently got upgraded broadband (white box) however the signal drops out in some of the rooms. How do I get or what are the best WiFi boosters to get?
Re: Poor WiFi signal
@Bags264 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
