Discussion topic: Poor WiFi connection away from router
Message posted on 04 Apr 2025 08:39 AM
Hello,
I have just moved to sky. The WiFi signal when in the room with the box is fantastic however when I move around the house the signal drops dramatically causing buffering and sometimes no connection at all. Can we resolve this?
Message posted on 04 Apr 2025 09:27 AM
Re: Poor WiFi connection away from router
@calum14 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
