Discussion topic: Poor WiFi Quality.
This message was authored by: Gavin-S
Poor WiFi Quality.
Sky keeps pixelating and freezing on all channels on all four pucka. This has been happening for the last week, we have reset all picks and the hub and have even isolated the WiFi so we have just one pick on it. Much of the time we have 400mbs but then it fluctuates. We have had a pc glitching too. Our hardwired camera has been fairly stable. Therefore it is probably interference but it is not coming from our house and we are detached. What can we do as watching Sky is no longer enjoyable.
Re: Poor WiFi Quality.
@Gavin-S Detached does not mean much if you do have close neighbours on the same wifi frequency, but the 5Ghz band wont be the one stretching out past your home though the 2.4Ghz band may do so. Best advice is to say what sky Hub you are using on the connection to start with!
