Discussion topic: Poor Wf
This message was authored by: NP26
Poor Wf
I have recently replaced BT broadband with Sky Broadband but the WiFi range is inferior and won't reach some rooms, including my ho.e office. Can the WiFi be improved so that it is as good as BT?
Re: Poor Wf
@NP26 The help / helps below to start with for you, see what is best!
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
and then if not this is your next sky option....
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
The BT Router that you had which one you do not say, then the equivalent one from sky would be the Black sky Broadband Hub, they are very alike and on par with each other! All the sky hubs are linked below if you need to look!
