Discussion topic: Poor Connection upstairs
This message was authored by: Morris78
In both bedrooms the wifi is buffering often. It's a really bad connection. It's been like this for a while. Seems to not be improving.
Re: Poor Connection upstairs
@Morris78 What sky hub and service do you have! Take it you where told to wait 14 day's for it all to settle in? See the link below if you are not sure what sky hub you have!
This message was authored by: Becky154
Did you find a solution?
our hub is upstairs in a bedroom yet our connection is the opposite bedroom is really poor, whereas everywhere else is fine
@Becky154
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
