Discussion topic: Poor Broadband Connection
This message was authored by: Paul__McElhone
Dear Sir / Madam, I am consistently loosing connection to my broadband. I have carried out all your tests and they all come back as everything is OK, but I know things are not. The connection is so poor using the Netflix, amazon prime and other tv apps can be impossible due the stop start nature of the connection and it make programmes unwatchable. Please resolve this urgently
Re: Poor Broadband Connection
@Paul__McElhone
You aren’t contacting Sky Customer Services on here. We are mainly customers trying to help other customers.
▪️I AM NOT A SKY EMPLOYEE ▪️
