Discussion topic: Podpoint EV charger not connecting
This message was authored by: Easypeasy
My EV charger won't connect to new Sky Max hub. Possibly because it uses 2ghz not 5ghz. Is there a workaround?
Re: Podpoint EV charger not connecting
@Easypeasy The sky Hub supports and transmit's on both the 2.4Ghz / 5Ghz bands unless you have a really old sky Hub from 15 years ago.
You may have to disable the 5Ghz as a temp measure, turn it back on once you get the device connected though!
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
