26 Sep 2022 07:50 AM
Hello, I have received my new hub on Friday and it's set up and working great. However my smart central heating has a power bridge which is connected to the hub with an Ethernet for connection and then a USB for power. This hub doesn't have a USB socket and I don't have a socket near by as this is located underneath the stairs (like in most new builds). I have read that you can convert USB powered gadgets to Ethernet powered as long as the hub supports PoE (power over Ethernet). Are you able to tell me if the hub does support this? Or suggest anything else? As currently my heating system is unable to be used which is concerning.
26 Sep 2022 08:01 AM
The sky hub doesn't support poe. I believe
26 Sep 2022 08:03 AM
Below is an example of a poe power injector.
TP-Link PoE Injector Adapter with IEEE 802.3af Compliant - Black (TL-PoE150S) https://amzn.eu/d/9JmIVBB
