Discussion topic: Plusnet to Sky
This message was authored by Rookey007 This message was authored by: Rookey007
Plusnet to Sky
Has anyone here moved from Plus Net to sky Broadband and any regrets pls
This message was authored by Darren1010 This message was authored by: Darren1010
Re: Plusnet to Sky
Just switched,trying to change the wifi password on the hub is proving difficult.Try to follow the instructions given but the Sky hub tab doesn't appear when looking in 'my products' etc.Seems like a lot of people with the same problem if you google it
Rookey007
Re: Plusnet to Sky
That a pain as if i move i was hoping to name the router and password the same as mine  now then wont need to alter any wifi set up in the house
Re: Plusnet to Sky
It has something to do with if you're using an IPhone/Ipad with Safari,you have to use chrome (just searched it here)
Rookey007
Re: Plusnet to Sky
Can you rename the wifi name too?
Apart from this what the speed and services like compare to plus net also the ping test.  Have you their top range wifi router?  Could you post a speed test pls
Re: Plusnet to Sky
You can rename the wifi(once you get to the settings)
Speed seems ok,hard to say,only switched yesterday so early days
Rookey007
Re: Plusnet to Sky
What was your reason to switch if you dont mind me askiing  Also how much you paying pls which pack
Rookey007
Re: Plusnet to Sky
love to know your reason of change pls
Re: Plusnet to Sky
I was paying Plusnet £32 for 150mb full fibre but got  Sky 500mb for £28,seemed like a no brainier
