Discussion topic: Plug extension
This message was authored by: Nathan87
Plug extension
Hi all,
I,m trying to find a power plug for the sky hub model SR204 that is 2.5metres long, I've tried loads of wire extensions but no size seems to fit. Does anyone have any recommendations? I've tried my volts but they don't seem to stick the correct one.
Kind Regards
Nathan
Re: Plug extension
Hi @Nathan87
Others have posted with the same question before. There does not seem to be a reliable 3rd party seller of power cables for the Sky hub so the solution is to just use a power strip.
I am NOT a Sky Employee
