Discussion topic: Please suggest replacement router with USB port compatible with Apple Time Machine
This message was authored by: Nashmills1
I have Sky's FTTP 300mb which is fine. I have been using the supplied Sky Hub with an Apple Time Capsule for backups and storage. I have learned that the Time Capsule won't be supported for Time Machine in a future version of MacOS so I have started investigating alternatives. The simplest solution for me would be to replace the router with one which has a USB port for network storage. I would also like to upgrade to Wifi 6 or 7.
Could someone please suggest a suitable router?
Re: Please suggest replacement router with USB port compatible with Apple Time Machine
@Nashmills1 You want and need that facility then it would be best that you do it all for yourself, NOT many ISP routers will even get close so you do need to start looking at third part options as your starting point, and what the usb support does, take a look at Asus and download the Operating documentation read carefully what/what not can be done usb port wise!
