Discussion topic: Phones run slow on sky
This message was authored by: PaulineC2
We've had sky stream for 2 weeks and we have 2 problems, phones are running slow compared to our previous provider Now and Ring doorbell wont connect to live view,any help would be most appreciated
Re: Phones run slow on sky
@PaulineC2
Is your wifi signal weak throughout your home as a poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
