Discussion topic: Phoned about WiFi not working
This message was authored by: Gail75
Phoned sky earlier today with complaints about WiFi not working, have been sent out a booster. We now have no WiFi at all! And having to use all our 4g.
nothing working at all
Re: Phoned about WiFi not working
@Gail75
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky again. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
