This discussion topic has been answered Discussion topic: Phone connection to WiFi
Message posted on ‎03 Sep 2024 10:19 PM
My Apple phone says it's connected to the internet but the connection keeps failing whenever I try and use Google or some apps, I've reset the router and forgotten the WiFi and reconnected but it won't have it, my phones Samsung has no problem also the Amazon fire stick is fine it just seems to be my phone. Apple iPhone 14
Message posted on ‎04 Sep 2024 09:49 AM
@Mike1661 Have you checked that you are not using the icloud relay and that your broadband sheild setting for Sky is not PG13.
Message posted on ‎05 Sep 2024 10:55 AM
Re: Phone connection to WiFi
Spot on thanks
