Discussion topic: Pet feeder connection
Message posted on 22 Jun 2025 10:18 AM
How do i connect a pet feeder using 2.4 GHz without compromising 5GHz network for all other devices
Message posted on 22 Jun 2025 11:18 AM
Re: Pet feeder connection
@Navin4 No idea what you have but if this router then use the link, if not then use the Tips at the top off the page.
Change your Sky Max Hub WiFi settings | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 22 Jun 2025 09:46 PM
A lot of 2.4ghz devices don't like WPA3 maybe set it down to WPA2 on the WiFi security. Might help if you say which pet feeder if that doesn't help .
Message posted on 23 Jun 2025 07:17 AM
Thank you. I have pet libro feeder
Message posted on 23 Jun 2025 07:18 AM
Thank you I will try that
