Discussion topic: Persistent Packet Loss Issues with Sky Internet
Message posted on 02 Dec 2024 10:03 AM
Hello everyone,
I’ve been facing ongoing issues with my Sky internet, and I’m almost certain it’s related to packet loss. While I’m not highly technical, I’ve gathered some information from my experiences and Sky support calls that might help clarify the problem. Any guidance would be greatly appreciated!
Overview of the Issue
Symptoms:
• Frequent packet loss makes online activities (gaming, phone calls, video streaming) nearly unusable.
• Examples include audio cutting out for 2-3 seconds on calls, stuttering/rubber-banding in games, and interruptions while streaming.
• This occurs on both wired (Cat6) and wireless connections, across all devices in the household.
Pattern:
• The issue is noticeable at any time, not just during peak hours.
• It sometimes worsens during high-activity situations (e.g., busy areas in games).
Steps Taken So Far
1. First Call:
• Sky suggested resetting the router via the WPS button and turning off the BT fiber port for 5+ seconds.
• Security was switched from WPA3-T to WPA2.
• Result: Slight improvement initially, but packet loss soon returned to disruptive levels.
2. Second Call:
• Troubleshooting confirmed the router setup was correct.
• A BT engineer was sent to check the line.
• BT engineer found no issues, claimed the problem might lie with Sky’s servers.
3. Third Call:
• The agent didn’t seem familiar with packet loss and focused on speed, which has never been an issue.
• A power cycle of the router was suggested but hasn’t been done yet due to work schedules.
Context and Frustration
Comparison with Previous ISP:
• With BT (on copper), we had lower speeds (50Mbps down/5Mbps up) but zero packet loss. Speeds are at current with sky 500mbps down and 75 mbps up.
Sky Fiber Experience:
• Despite upgrading to fiber for better reliability, the packet loss has made the internet unusable for most of the household.
Technical Observations:
• Packet loss appears to occur between the router and the server, not between devices and the router.
• No improvement with wired connections.
• Pings like below look the same on all devices, i.e. when a connections times on out a wired pc, it will drop simultaneously on a wireless one if testing at the same time.
Pinging googles server:
Pinging the router at same time:
Request for Help
Does anyone have experience troubleshooting packet loss with Sky or suggestions on what might resolve this? I’ve already ruled out many basic fixes, and I’m struggling to get meaningful help from Sky support. The issue affects the entire household, and given the cost of fiber, this is incredibly frustrating.
Any insights or advice would be greatly appreciated!
Message posted on 02 Dec 2024 12:26 PM
Re: Persistent Packet Loss Issues with Sky Internet
Packet loss can occur on fiber optic networks due to various faults, including:
* **Fiber optic cables:** These cables can become kinked or damaged, affecting signal transmission.
* **Connectors:** Connectors can become dirty and require cleaning to restore proper functionality.
* **Optic transmitters:** Low signal strength can occur due to faulty optic transmitters.
* **Distance between transmitter and receiver:** Excessive distance can hinder signal propagation.
* **Incompatible cables or ports:** Ethernet connections using faulty cables or ports can result in packet loss.
* **Broken fiber cables:** Damaged fiber cables can disrupt signal transmission.
Message posted on 02 Dec 2024 02:27 PM
Hi,
Thanks for the reply!
Are there recommended ways to test whether the issue lies with the fiber optic cables, connectors, or optic transmitters? For example, are there tools or methods I can use to check signal strength or detect kinks/damage in the cable?
Message posted on 02 Dec 2024 02:31 PM - last edited: 02 Dec 2024 03:30 PM
Essentially no, unless you happen to work for Openreach. Strictly speaking it's not legitimate for civilians to be touching the fibre-optic side of the ONT at all, apart from perhaps unplugging and reseating the green SC APC connector as part of basic troubleshooting.
Message posted on 02 Dec 2024 03:16 PM - last edited: 02 Dec 2024 03:18 PM
Are your Ethernet connections going direct to the hub or are there any switches in play on the network? A faulty switch can't be ruled out if so.
Are you running CCTV? If so can you try unplugging it temporarily to see if things improve.
Is there anything running in the background, such as a pc running Steam or a Torrent client?
I appreciate that it appears to have run without issue previously while I no FTTC, but wonder if anything elee may have change recently.
These are obviously things which could cause issue up to the router. Any issues with the fibre itself mostly lies in the Openreach domain and becomes only becomes a Sky issue when it hits any Sky equipment at the exchange.
Unfortunately if there are network issues outside the home causing packet loss this could be quite difficult to initially identify and resolve. If you are certain that everything in the home is bullet proof, checking things like I suggested above, it may be worth another call to Sky to see if they can get the network team to look it it.
Message posted on 14 May 2026 06:20 PM
I have all the exact issues you have! I stopped complaining about it few years ago after years of complaining. I thought upgrading to sky fibre 500 down 70 up would resolve my packet loss issues and make gaming fun again...
It did not. I'm out of contract with sky in October and I'm already getting excited to try out trooli or hyperopic. With a few months remaining I may just pay off sky to speed up end of contract. Sky or ok if you browse the internet or watch YouTube, they are not known for being good for gaming. Even when you look at their website gaming is nowhere to be seen it's all about movies, usually a few minions in there somewhere. Forget using your own router it makes no difference. I have had tp link fritzbox and Asus. All are good for a few hours gaming before reverting to a default state of garbage again. There is no cure as it were. If you are a good player in cod halo or any other FPS games you will be nerfed by sky's packet loss not your skill. The only option in this case is to leave sky. The guys in this thread that help, and they can be helpful! They cannot help resolve this. Gareth
Message posted on 19 Jun 2026 05:34 AM
This is the exact issue I'm having. I just joined sky and my experience hasn't been good. The issue isn't the speed, it's the packet loss and the sky app keeps saying there's no issue. I presently use my mobile data when I have meetings.
Message posted on 19 Jun 2026 07:44 AM
@Awhy04 it would seem a few customers do suffer a high level of pscket loss while the vast majority do not. Assuming you have eliminated the possibilty of issues within your home network as WiFi interference is a prime cause followed by the Sky hub being overloaded by too many simnltaenous users once excluded then the issue could be a line fault as discussed in the thread above.
Unfortunately as you have discovered Sky's disgnostics do not pick up packet loss so it is difficult to evidence. The site thinkbroadband.comhas a useful Broadband Quality Monitor (https://www.thinkbroadband.com/guides/broadband-quality-monitor) which should pick up the issue but as far as I know the white Sky hubs do not respond to the incoming pings so cannot be monitored unlike the older black Sky hubs which do work. It is worth percevering with. Sky as polite persistence can get these issues escalated to the network enginerrs who work with Openreach and City Fibre whose links are the next likely cause their engineers carry equipment thst can assess the quality of the link.
Avoid the temptation to let rip as while it may make you feel better your complaint is unlikely to be escalated.
Message posted on 19 Jun 2026 07:48 AM
@Awhy04 wrote:This is the exact issue I'm having. I just joined sky and my experience hasn't been good. The issue isn't the speed, it's the packet loss and the sky app keeps saying there's no issue. I presently use my mobile data when I have meetings.
I've just tried a 100 count ping test to the Google servers and got back a 100% success rate so I'm not sure why yourself and @Fearitself are having issues, it certainly can't be a systemic Sky issue if mine is fine.
How have you tested?
I'm currently running a 1,000 test run although there's always the possibility that Google themselves drop heavy volumes of ping traffic during high congestion periods to save bandwidth.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 19 Jun 2026 07:49 AM
I should add, I'm testing via a PC hardwired rather than through wifi.
Not a Sky employee
Message posted on 19 Jun 2026 08:03 AM
That's the 1,000 count to Googles servers completed at 100%
Whilst I was waiting (it takes just under 17 minutes if you're trying that 1,000 count) I downloaded Ping (Hamed.Ninja) on my Android phone, it's connected to my Deco BE65 via wifi and got up to a 150 count with no errors.
Not a Sky employee
