Discussion topic: Paying for giga and only getting 350mbps
This message was authored by: Aaron61
Why am I only getting 350mbps when I'm paying for a giga?
Re: Paying for giga and only getting 350mbps
@Aaron61
What device are you using to measure the speed and what speedtester are you using
Best using a device etherneted to the hub and test it on fast.com
Avatar for Aaron61
I think it's something to do with the sky hub. I have been reading that they are not great
@Aaron61
Speed is only 'guaranteed' as far as the Hub: WiFi is always zero Mbs after going through a few walls.
Sky Hubs, like any other ISP router, are built to a fairly limited budget.  Realistically Gigafast broadband is intended to provide 'enough' bandwidth for multiple devices rather than peak headline speed to a single one: for that you'd really want ethernet cable.
This message was authored by: peter-marlow+1966
Have you  got  gigafast  broadband  fttp 900mps  full fibre  to  the  property   ?
P c marlow
Avatar for Aaron61
Yes I have
Ok I would ring  sky
P c marlow
@Aaron61  AS @cookiemonsteruk  asked what device are you measuring the speed with and how is it connected to the router?
Avatar for Aaron61
Measuring speed from my phone on speed test on Google and I have a WiFi speed test app as well
