Discussion topic: Pausing specific devices
This message was authored by: Ktfh2727
Message posted on 05 Dec 2024 09:17 AM
The option to pause the internet signal to a specific device has suddenly disappeared from my device
Find out more
Message posted on 05 Dec 2024 09:41 AM
Re: Pausing specific devices
@Ktfh2727 the only way to pause devices requires you to have bought the WiFi Max add-on as the Parental Controls in thst bundle allow you to do thst vis the My Sky app. If thst is not working try rebooting the Sky Max hub by disconnecting the power for a few seconds. If that doesnt work give Sky a call.
