Discussion topic: Parental controls sky max?
This message was authored by: Nickjett
I've recently upgraded to sky max as the intwrnet speed in our bedroom was poor. Tbh it still isn't great. But I was under the impression that there would be parental controls in the sky app once I upgraded to sky max but I don't see anything new in the app?
Re: Parental controls sky max?
@Nickjett  Normally those controls are under the broadband & talk tab on the Sky app, but might have been moved with the new max router from Sky.
Avatar for Nickjett
Avatar for Nickjett
That's all i see
Avatar for Nickjett
Thanks...but none of the options to create a profile or anything to do with parental controls are whete the article says it should be
@Nickjett You are sure that you have the Sky Max addon in your package with the additional monthly cost?
Avatar for Nickjett
I upgraded just over two weeks ago...the upgrade is an extra 4 pounds and I have thecwhite router since the upgrade
@Nickjett Time to call sky then something set wrong and you are not seeing the required switched on through your app to your account and the sky max option.
Avatar for Nickjett
Ok thankyou
@Nickjett Guess not looking forward to the wait, try early tomorrow morning quite time and you may just be lucky.👍
