11 Oct 2024 01:54 PM
Rather than use a WiFi connection, I've always connected my ps5 to the Internet (sky broadband) via an ethernet cable into my sky q box for better speeds and less lag.
Today the connection stopped and won't reconnect. I've reset the router, reset the sky q box and the network connection between the box and router.
All appears okay, Internet is fine. Sky q box is fine, can get the ps5 online via hot-spot or WiFi (slower speeds) but when I try to connect via LAN on the ps5 it says 'can't obtain an IP address within the time limit'
Any ideas on how to fix would be appreciated?
11 Oct 2024 06:14 PM
Posted by a Superuser, not a Sky employee. Find out more@Curbmyenthusiam there is no point in connecting to the Q box's ethernet port. The tv boxes are not designed to act as a wifi bridge and even if it worked you would still get lag etc as the Q box is connected by WIFi. While direct Ethernet cables to the Sky hub will cut latency and improve stability it has to be a direct connection. If that is impossible look into using a powerline networking kit that uses your home's mains wiring to carry the data which is often better than WiFi.
11 Oct 2024 08:04 PM
Thanks. Very helpful. 😊
