Discussion topic: PON r
This message was authored by: Fraser75
PON r
PON red light on ont. switched on and off numerous times and still red.
No device can connect to wifi
Re: PON r
@Fraser75
This will need reporting to Sky so try running this line test to see if it finds any faults:
If this is of no help give Sky a call to report it to them so they can look into this for you.
Re: PON r
@Fraser75 Follow the advise from @caesarome and call sky, the Pon may clear and go good with Green again but is best having sky to look at it for you!
