Discussion topic: PON light flashing
This message was authored by: Billy921
PON light flashing
PON light on ONT has suddenly started flashing - tried a power cycle and checked cables all seem OK.
Can Sky / open reach see the issue or do I need to call up (or just wait for it to resolve)
thanks
This message was authored by: Kpps
Re: PON light flashing
Same problem in Paignton area.
This message was authored by: NickNewark
@Billy921 @Kpps I would go through the Sky app and check the broadband status. This should allow you to raise the issue and Sky can alert Openreach and possibly book an engineer appointment if needed. I've had one issue in the past with the ONT and it was an external network fault.
This message was authored by: whatcanisay
Hi, how did you get this resolved as I've currently the exact same issue.
