1
This discussion topic has been answered Discussion topic: Outage of phone and wifi
This message was authored by: Sas+Daborn
Everything went down?
I pay everything to you guys and I'm out with phone and broadband, compensation please
Re: Outage of phone and wifi
@Sas+Daborn
There is no compensation for short term outages.
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it's not use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
@Sas+Daborn
