Discussion topic: Outage in Medway
This message was authored by: Catherine5un
Outage in Medway
Just been told there is an outage in Medway how do I check if this is correct, is could be the weather, not saying Sky are fibbing but my neighbour is still working so I dont understand
Re: Outage in Medway
@Catherine5un
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
