Discussion topic: Outage in Keswick
Message posted on 28 Feb 2025 07:06 PM
Outage in Keswick
Not had any broadband for 3 days, does anyone know what is happening?
Message posted on 28 Feb 2025 07:11 PM
Re: Outage in Keswick
@Suer70
If you’re still having problems you may need to call Sky to report it (dial 150 free from your Sky Talk landline [if it’s still working]).
