Discussion topic: Orange voice light
This message was authored by: Condog99
Orange voice light
WIFI suddenly down. We don't have a landline We have fibre. We can connect to the WiFi but it says no access to the Internet
Re: Orange voice light
@Condog99
If you have fibre then you have a landline as that is how the phone part works as it comes down the same line.
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
Avatar for Condog99
Level 0 icon
Hi
No reported outages.
I've unplugged everything turned everything off, restarted it but no difference
And the result of the line test ?
If nothing shows and it isn't working try the test again in an hour or so.
Avatar for Condog99
Level 0 icon
Hello,
The 2 links took me to the same thing and everything came up as "normal"
