Discussion topic: Orange lights
This message was authored by: Lerigo99
Orange lights
My wifi keeps disconnecting and showing orange lights. When I check the connection on the app it says there is no issues with my wifi or broadband, except clearly there is.
Re: Orange lights
@Lerigo99 Do you have the 4 light hub, and two are going amber, internet and possibly voice, they do have names under the lights or look at the link.
Re: Orange lights
@Lerigo99
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
