Discussion topic: Orange light on router
This message was authored by: Aliciajayd
My Internet comes on for a second then light goes to Orange on router above Internet sign
Re: Orange light on router
@Aliciajayd About the lights and the checker are linked below! both will allow you to check but you may have to do that over mobile data if your Broadband is down as indicated by your light!
