Discussion topic: Orange light on I
This message was authored by: Kellyxxxx
Orange light on I
Help no internet
Re: Orange light on I
@Kellyxxxx
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
