Discussion topic: Orange flash on router
This message was authored by: Amy335
My ONT has the 2 green lights for power and pon and the blue solid light for data but the router has an orange flashing light and there's no WiFi connection. I have fully unplugged everything and reset the router. Still nothing
Re: Orange flash on router
@Amy335
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
