Discussion topic: Orange Voice Light
Message posted on 28 Oct 2024 04:51 PM
Orange Voice Light
Message posted on 28 Oct 2024 05:21 PM
Re: Orange Voice Light
Next time it happens try running the line test here:
Message posted on 28 Oct 2024 06:49 PM
Message posted on 28 Oct 2024 07:02 PM
@Peterjames24 The issue is caused by a fault with the server managing your connection. It can normally be sorted by turning off the hub for an hour which should force a change of connection node. At any one time a small % of the over 5 million nodes have this fault they do get repaired but it takes a while.
Message posted on 28 Oct 2024 09:52 PM
Thanks ...any idea how to stop it happening? Everything runs through the hub ..heating, cameras etc ...can't always be around to switch it off and wait. There is quite a few threads about this on the forum...seems to be a bit of an ongoing issue.
