Discussion topic: Orange Flashing Light on Router
Message posted on 19 Dec 2025 05:42 PM
Message posted on 19 Dec 2025 05:45 PM
Re: Orange Flashing Light on Router
@jamesbarrie88 You can try running this link below to see if it reports anything, but time is required to be past before it does!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
Message posted on 19 Dec 2025 05:48 PM
Message posted on 19 Dec 2025 06:31 PM
@jamesbarrie88 The diagnostic if you wish via the lights or direct!
Try running the line test here to see if any faults are found:
or
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
