This discussion topic has been answered Discussion topic: Openteach delays
Message posted on 04 Feb 2025 11:45 AM
I have waited for open reach to do some work for full fibre why send messages that it's available when it's not
Message posted on 10 Feb 2025 03:56 PM
What do the rest of the notes say?
Does it mention wbc fttp in the table?
Message posted on 04 Feb 2025 11:48 AM
Re: Openteach delays
You need to clarify a bit more. Have you ordered full fibre? If Sky have said its available what says it isnt?
Message posted on 04 Feb 2025 12:16 PM
@Sunuy the service can be available in your road but runningthe cable to your home can be more complicated than expected. If you put your full address in the following checker and post the table with the first 3 lines of the notes after obscuring that reference to your address it should be possible to see the issue Openreach Checker
Message posted on 10 Feb 2025 03:53 PM
Hi it says the exchange is not a current priority
