Discussion topic: Openreach delays again for fibre
This message was authored by: Gaming21
Hi is it worth cancelling or not at this has been going on for 6 months waiting for fibre to be fitted and all we keep getting is update after update it's like I've been pushed aside and forgotten about excuse after excuse for install
Re: Openreach delays again for fibre
Have you spoken to Sky to find out why there has been this lengthy delay ?
Avatar for Gaming21
Level 3 icon
I have and they just give me the excuse openreach has escalated my case etc but that's all we get nothing else quite useless really
@Gaming21 Just finished neighbours yesterday, available 1st Sept 24, she did order Nov 2024, just installed Jun18th 2025, all because VM stuffed the crossover duct's and OR had no way to get back to the pole's, so they are now digging path's across roadway and down the pavement with civil's as and when ordered by customer's it is one huge mess but at least they are doing it and no doubt very costly.
@Gaming21
Might be worth doing the bt wholesale checker again
Did you complete the on line enquiry form and what was their response?
Next step would be to email the CEO of Openreach.  When my broadband went  down sky gave it to me to me after we reached an impasse on why it was taking 3 weeks to fix an internal fault.  They created a complaint number on their side and i emailed openreach seperately
Avatar for Gaming21
Level 3 icon
Yh I had emailed etc and got f all back from openreach I've used the bt checker and still the same no change I'm having to use my data as wifi
Avatar for Gaming21
Level 3 icon
Ooooof bit like mine then long time to wait for it ay
@Gaming21 Not for me on the good side, working like a dream!
Avatar for Gaming21
Level 3 icon
Lucky you I don't really know what else I can do
@Gaming21 There is absolutley nothing it's all in the hands off the infrastructure Engineers, and they are just trying to keep the fire from burning there feet one job at a time.
Avatar for Gaming21
Level 3 icon
It's ridiculous I will probably end up cancelling if they don't have me active by july
@Gaming21 Unless you have another way to go then it's all your choice.
Avatar for Gaming21
Level 3 icon
Unfortunately I don't as its all through openreach isn't it
@Gaming21 Not if you have an Altnet supplying Fibre and running past your address? OR are not the only game in town!
Avatar for Gaming21
Level 3 icon
Hmm very true
