Discussion topic: Open reach los red light
This message was authored by: ClarkFennell
Hello, my broadband and modem are working but my openreach ONT is showing a red light. I have no access to the internet at all. I need this fixing for work NOW.
Re: Open reach los red light
@ClarkFennell
We are customers here so can not fix this NOW for you.
As you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
