Discussion topic: Only 2bars showing
This message was authored by: Babs20
Only 2bars showing
Only 2 bars showing
Re: Only 2bars showing
@Babs20 if you arecreffering to the WiFi signal strength the folowing is likely to apply.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
