Discussion topic: Ongoing WiFi issues
Message posted on 01 Sep 2026 05:34 PM
Ongoing WiFi issues
I'm having ongoing WiFi Connection issues. I recently received a WiFi booster from Sky but this hasn't worked. I thought the issue was with my Ring doorbell so I was sent a new one out but the issues remain on the Ring doorbell when I try to check out live view on it. Also I've noticed numerous apps on mine and my wives phones aren't working unless we turn phone WiFi off
Message posted on 02 Sep 2026 11:19 AM
Re: Ongoing WiFi issues
Hi @Chippo1
What exactly are the WiFi issues you are experiencing? If its a coverage issue, typically a booster would solve this. If its a disconnection or speed issue then a booster may not.
Also regarding some apps not working, try disabling Sky Shield. https://www.sky.com/myaccount/bb-and-talk/broadband-shield
Message posted on 02 Sep 2026 02:20 PM
WiFi dropping terribly and booster isn't working. Can't even go live in my ring doorbell which is next to my Sky Broadband Hub. What do I do now? Why can't I report a fault via My Sky App?
Message posted on 02 Sep 2026 04:20 PM
I had the same issue with my Google home doorbell. I swapped to a mesh network (eero) and switched of WiFi on the max router and Everything magically works. Although my speed is flakey compared to Virgin Media. I'm not sure if it's a poor router, or if SKY want's you to buy their new doorbell, but it's definately the router at fault.
