Discussion topic: Ongoing Broadband Issues
This message was authored by: Jack1507
For several weeks now our home broadband keeps failing and we have to spend 30+
minutes going through the various reset/reboot procedures listed online by Sky.
It has always come back to life eventually, but this is now becoming a daily occurrence and not ideal when you work from home. The service checker online is useless as it always says everything is done despite nothing working and the sky website doesn't seem to offer a telephone number to contact customer support for help...you just go round in circles being told to check the service and turn everything off/on.
Any suggestions for how to resolve this? Are there ongoing issues in the Reading area? Is it possible we need a new router (ours is approaching 4 years old).
Any suggestions would be greatly appreciated.
Re: Ongoing Broadband Issues
@Jack1507
▪️I AM NOT A SKY EMPLOYEE ▪️
