Discussion topic: OUTAGE FOR 2 HOURS 27/11/25
Message posted on 28 Nov 2025 12:53 AM
Outage of broadband for two hours Thursday night and Wednesday night every time every week same
Message posted on 28 Nov 2025 03:16 AM
Re: OUTAGE FOR 2 HOURS 27/11/25
@Alexg88
If you have broadband issues between midnight and 0700 it’s likely to be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
If it's not back by 7am, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
