2
This discussion topic has been answered Discussion topic: OTN in garage
This message was authored by: MarlWa
OTN in garage
Hi
Quick question.
Unfortunately the house I moved in have Open reach fibre hub in garage and this is where the sky hub is connected.
The reception in garage is fantastic but in rest of the house not so much.
House is hard wired so got ethernet ports down and up.
What equipment would be best to provide 500Mb ish in whole house over wifi same as garage?
I'm assuming that sky hub needs to be plugged into OTN?
Many thanks.
Re: OTN in garage
@MarlWa
If the house has ethernet, is there an ethernet cable between house and garage?
If so the Hub can go on the end of that.
Re: OTN in garage
@MarlWa
Avatar for MarlWa
Re: OTN in garage
Hi
Yes there is.
I will try that in morning.
Thank you
