Discussion topic: ORDI Request Help
This message was authored by davejh001 This message was authored by: davejh001
ORDI Request Help
Hi,
I'm having a bit of a merry go-round on trying to get my address listed properly with Openreach on the OR Database - with the FTTP rollout and me needing to change provider to get a Static IP address for work, things are a seemingly impossible.
I can only get FTTC services, I know this for a fact. Theres wayleaves etc required to get Fibre into the building which is going to take a long time as there's a management company involved and all that fun, and Openreach have said its bottom of their list in terms of rollout.
When i put my address in the services checker I can only avail of FTTP because of the way its been built on the OR DB. My address is a gold key, but its listed as a house number, as such, ie
4 Old Street, Town, Postcode.
To actually get the service I need (FTTC), I need to use the Silver Address key, which I need someone in SKy to do an ORDI to do this to get it updated. A couple of my neighbours (in the same block) have their addresses built as the following below as a gold key, which is what I require to enable me to order a new service.
Apartment 1, New Flats Block 1-6, Old Street, Town, Postcode
They also have their address on the ORDB built as it being as 1 Old Street, Town, Postcode, where it states they can get FTTP but all of us in 4 different blocks know this is invalid information and not possible at present, and would be lucky to get it even this year.
Been on the phone a couple of times about this and just goes nowhere.
Dave
This message was authored by daveNOS This message was authored by: daveNOS
Re: ORDI Request Help
@davejh001 I don't think Sky will help if you are leaving them, you may need to raise the issue with whichever new provider you decide to move to.
davejh001
Thank you for the response @daveNOS
I have been onto another provider and they informed me as Sky is my current provider, they are the ones that have to do this, as if i cancelled my service with sky, I would be left in limbo with no services until the problem is rectified, which from reading from other forums, could take a while!
