Discussion topic: Nothing working
This message was authored by: L4
Nothing working
No internet broadband connection or booster working
Re: Nothing working
@L4
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
Avatar for L4
Level 0 icon
Re: Nothing working
It keeps going off and on I reset everything and it goes off again to be honest I don't know what else to try I've done everything I could possibly do next step an engineer
Re: Nothing working
@L4
What was the result of the line test you ran ?
