This discussion topic has been answered Discussion topic: Nothing is working
Message posted on 21 Jan 2026 10:28 AM
The internet light is orange and so is the voice light
Message posted on 21 Jan 2026 10:30 AM
@Den65
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
@Den65
