1
This discussion topic has been answered Discussion topic: Nothing connected
This message was authored by: Bren12345678
Nothing connected
Nothing is connecting to my WiFi and an orange light is showing on my hub.
Re: Nothing connected
@Bren12345678
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
▪️I AM NOT A SKY EMPLOYEE ▪️
@Bren12345678
